For Sale - 2006 Dodge Ram 2500- Flatbed for long box bed Winch bumper Flat Bed for Long Box 3rd generation Cummins Tootlbox are included with key I have a flatbed for 3rd Generation dodge Cummins. This flatbed comes with a gooseneck hitch already in the bed. The winch bumper is part of the set. Tootlbox have a key to lock and unlock all box a single key. There is rust starting and electrical will have to be sorted out on your own.
Price: $1,000.00
Seeing how I cant find hardly any answer on these things,other then there garbage. I need to know some things with it. I dont mind mine,( half the time when im not hauling) seems like it pulls great with a new clutch in it, I figured out it doesn't like to speed shift at all, which really sucks hauling a trailer around town on hills,
Here is some of my downfalls with this one in my 92, when i bought it the guy said the sycro was going out in 3rd and 4th, when i test drove it... 3rd was bad had to float into it, but 4th wasn't, but the tranny feels really tight and strong, i dont think its getting worse, but it is definitely annoying! He included another getrag with it when i bought it, said its a perfect tranny,( came out of another 92 he said, but the guy couldn't use it because he was putting down some serious HP is what this gentlemen told me) what should i do before i swap it in? I already got told to feel the scryos in that one, is there anything else i can do to help it out while i have it apart? Beef it up a little, im by no means a tranny guru, so if its not really bad or hard to do,
How much gear noise is suppose to be there>? i have asked around about this..some have said a little.... the one thing that i have found odd is when i push the gear shift over towards 5th, i have really reall bad gear noise, almost sounds like its hitting the bell housing, It will some times do it when im sitting at a light and idling, or after long drives. it doesn't bog down the engine at all, ill watch the rpms and they stay steady,
Here is a blonde question,
i couldn't find this answer, so im asking it here, can i pull in 5th gear with a trailer on? the gentlemen that i bought it from says he does it all the time, because it has 4:10 gears, i have yet to do this because im worried about the output shaft and the input shaft, i have heard and read that there not the strongest by no means, to me 5th was still a overdrive gear like a nv4500.but he said he did it all the time
To top it all off today, i snapped my gearshift.
how i did it is beyond me, other then i think it has been done before, and someone else welded it to a bolt. which i broke the bolt!! the icing on the cake. i was going up a steep *** hill, when to turn around, put into reverse and snapped it. like oh F****, now what. took the cover and rubber peices off, finally kicked it out of gear so i could let the clucth out after holding it down for 10 mins with the brake so i did kill it or kill me going to the back side of the wrong way hill!!!
Dont mind my weld porn,
it was just 110 wire fed with no gas!! what a B****...... first time for everything haha
Edited by fuze24v
