DTC P0072 cant't be cleared after installing a new ambient air tem sensor twice
- Replies 3
- Views 2.2k
Hans 2 posts
Mopar1973Man 1 post
I would like to clear the check engine light and clear (permanent?) DTC P0072 so I can smog my truck. P2509 also comes up. Dealer wants to flash the PCM for $175. I already repaced the ambient air tem sensor twice, wireing inspected... Two years ago P0072 went away after installing the new sensor. Thanks
5 Volts are going to the sensor and the sensor reads 11000 Ohms. Is there any way to clear codes on a 2007 5.9 ? My Bosch OBDii scanner erases every code except the P0072.
Clains the current is low but it has 5 Volts going to the sensor.Truck runs perfect except for windshield wiper electrical flaw.They stop in the middle of the window and the lowest setting doesn;t work.Noticed that the windshield wipers are on the same wiring group/diagram. Mabe a corroded ground?
Edited by Hans
update
