Problems Hoohing up new sport Headlights "NEED WIRING DIAGRAM"
eventually I get to deal with this to some extent, hopefully it won't be as painful. there is a ton of schematics over at hidplanet, they have an entire thread dedicated to building custom harnesses. although you have to be a member to view anything there. might be worth a shot for some ideas at least.
well even hidplanet I couldnt find an exact answer, the 2nd gen trucks have a bit of a strange setup in some regards. the positive supply line is always hot whether the switch is in any position. so i took some time to design one. I have yet to build this but I think my engineering skills will be fruitful at least.
i might need to make a larger picture or just go over to photobucket, although I do not have a premium membership to host it.
On the left side is just a generic diagram explaining how the stock wiring is supplying voltage, its not detailed on that part in any way. on the right side is the harness, only thing I forgot really was to add a 20A fuse on the 12volt supply. the only issue we might have is a slight flicker when switching from low to high. I might add a capacitor to the low beam circuit to counteract that if that is the case.
