Hi All looking to replace a Gen 2 map sensor with a heavy duty one.  I have located severall sensors but I don't know the correct thread pitch or style.  I have several to choose from and the only O.E.M. one I have is in the running truck.  So hopefully someone knows or can pick it out of a line up.
TIA  Michael
MAP Pressure ports.pdf
  • Replies 3
  • Views 1.8k
Why?
MAP sensor rarely goes bad. Just buy a normal MAP sensor and install. Heavy Duty isn't going to change anything.
Ah but this is for a dedicated Pull Truck (tractor Racing style) and they are making Killer Boost.
So I found a 0-100 PSI pressure transducer.  Just looking to match the threads.
Thanks
Michael
Found it M 14 x 1.5 is the thread pitch.
Thanks
Michael
Did This Forum Post Help You?
