I have a 1999 ram 2500 sport that previous owner put some crap aftermarket led headlights on.  I ordered oem 4 bulb (2 each side) headlights and repaired patched in wiring.  Once installed the inner bulb on each headlight works as both hi and low.  The flashers and running lights work.  The outer headlight bulb on each side will not light hi or low.  On my way to get my multimeter now.  Do the outer two bulbs light on hi only or low and high?  Are they a separate fuse?  I don't see any cuts like the mains had.  P.s. this is a true sport with 2 headlight cables per side not a conversion.  Any help is greatly appreciated.
  • Replies 4
  • Views 2.4k
Yes.  They came with the oem light bulbs installed.  I'll pull them to be sure.  I also bought spares so I can switch to those too.
Update:
So the bulbs are correct bulbs.  I took the volt meter to the two inner headlight bulbs and they are not getting power.  Btw its the two inner bulbs that arent working not the two outer.  The inner bulbs only have 2 wires.  The outer have three and work on hi and lo.  Guessing the inner are just for low?
Update2: solved
Problem was blow fuse.  On sport model there is 1 fuse for left hi and lo bulb, 1 fuse for right hi and lo bulb, and a third fuse (quad lights) for the 2 inner bulbs that work with the right and left outer bulbs (hi or lo).  This 3rd fuse was probably blow during the previous owners attempt to hack in no compatible headlights.  Hope this helps someone else too.  Thanks for the replies I got!
Edited by Diesel Don
Solved
The light next to the turn signal marker will operate as a hi/lo beam. The othe bulb towards the grille is only high beam. It has its own relay and fuse.
Here you go...
Headlights w/Quad wiring map 1999 Dodge Ram
