I have a 2000 24 valve with a p7100 pump and I've been investigating a fuel knock that I've had since I've had the truck. I've replaced the injectors so my next step is the injection pump.  I'm looking for the best/cheapest ways to test the pump without removing or taking it to a shop. Thanks.
You might be able to check each barrel for pressure. Like compression check on an engine. You might have a bad plunger in one of the barrels too. Either way those can be replaced. Also there are some centrifugal weights that might be going bad. I would bet on a plunger tho.
