Ive have searched High and Low and can Not find an answer to this. But to make sure I understand.
I have a quadzilla adrenaline V2 installed in the truck. I have tried to make it high idle with parking brake ect. when it was cold as ever.
No high idle
I have purchased a Moparman high idle switch from DAP and look to install it.
Can i install it with current quadzilla plugged in everywhere?
And If i need to flash the Computer to enable high idle either with a smarty or a dealer.... can quadzilla stay plugged in?
If this is a dupe post please let me know. Thanks for all the infinite wisdom you guys have on here. Finally signing up
Truck is a 2001 24v 99% stock with a rebuilt auto.
  • Replies 1
  • Views 1.4k
The quad doesn't care about an ecm flash.  You can install them side by side, just make sure you disable the quadzilla high idle.
