- Replies 3
- Views 4k
cs15dah 2 posts
farming24v 1 post
Okay, fellas I need some help understanding what I'm seeing here.
Over the past several drives, when I first start the truck up the BRAKE and ABS lights might stay on for a short bit (less than a minute) and then go out. Once or twice, I also caught the speedo popping up as I started to drive. Like it was at 0, then suddenly popped up to whatever speed I was going, 20-ish MPH... I wasn't really watching it, so I'd sorta see it happen just outside of my view.
Then today, idling for about a minute in a parking lot, about to leave, the NO BUS message appears in my odometer, the MIL, ABS, FUEL and the AIRBAG lights are illuminated, and I lose my gauges. The truck still idles fine, and I was able to drive away, but was sluggish on acceleration and had to vary the throttle for upshifts.
I get home and start troubleshooting. I found multiple threads about NO BUS and P1698 (my only code) so start going down the PCM path. I test for continuity/ground at C1 pins 30 and 31. Tested for 12V at 2 and 22(?). I can't recall the ohm on 30, so I'll have to go back out and check. While in there, I took all three connectors off and shot both the male and female sides with electronic parts cleaner. The connectors didn't look bad, but worth a cleaning anyways. The grounds were tight. In the fuse box, the bolts were all tight. No fuses appeared blown. Battery cables were all tight. The large connector in the center of the firewall over the engine appeared to be tight.
Reading online, it appears if a 5V sensor on the bus isn't behaving itself, that could cause the NO BUS problem. Since I had the strange popping up speedo, along with the random ABS and BRAKE lights, I thought I'd try to eliminate that by unplugging the rear ABS sensor. So the sensor is still in the differential housing, but the connector is just sitting there. I take it out for a test drive, and I have a working speedo? I thought the truck got it's speedo input from the rear ABS module? Am I incorrect? Still have the NO BUS problem. Reconnected the sensor.
While under the hood, it sounds like a relay in the ABS module is rapidly clicking, randomly. I recently had it rebuild by Module Masters, so not ruling out a problem with the ABS module. Just saying it's low on the list of culprits right now. But strange enough, when I take it out for a drive, the truck runs perfectly. All the needles work correctly. And the only light on the dash is the ABS light.
I'm at a stopping point for now. So curious as to what you guys think I should check next. And, let me know about where the speedo gets it's signal from??
Edited by cs15dah
further troubleshooting
