For Sale - 2006 Dodge Ram 2500- Flatbed for long box bed Winch bumper Flat Bed for Long Box 3rd generation Cummins Tootlbox are included with key I have a flatbed for 3rd Generation dodge Cummins. This flatbed comes with a gooseneck hitch already in the bed. The winch bumper is part of the set. Tootlbox have a key to lock and unlock all box a single key. There is rust starting and electrical will have to be sorted out on your own.
Price: $1,000.00
Ok, a little backstory- the truck has a build date of 8/99, auto 2500 with 370k miles
I bought this truck recently with a bad transmission but had a reman in the bed. I dropped the reman off at a tranny shop to have them check it out and picked up a single disc torque converter while I had it out. The tranny checked out ok so I swapped the transmissions. On initial install, I only had 1,2,3 shifts with no od and no lockup. I dropped the pans on both and noticed the pressure sensors were different. I swapped the od solenoid, pressure sensor, and wiring harness from the original tranny to my new transmission. By doing so, I was able to pick up od and lockup but not it will not downshift from 3rd gear unless I do it manually. I bring it to the tranny shop to have them read the pressures and figure out what’s going on before I just start throwing parts at it. They were never able to get the scanner to read anything from the obd port.
This brings me to my current issue. I have power and grounds on the port. I checked resistance and the violet and blk/white wires from the cluster to the pcm and they all check out good. I’m stumped as to where to go from here. The reason I bring up both issues is I’m wondering if they could be related? I’m leaning towards the pcm being bad but I don’t want to just throw one at it and see what happens. Does anyone have anymore diagnosis tests for the obd port? Or any insight whatsoever? Thank you
Jim
