- Replies 5
- Views 2.3k
Mopar1973Man 2 posts
ISX 2 posts
Zacharynels 1 post
I made an article on fuel pressure and am having some issues. I think I know what the problem is but I figured I would keep tabs of the problem on a thread so someone else can learn too. In that article, my fuel pressure tops out at ~22psi. It is supposed to "never fall under 25psi under a load" so the fact that it was just idling and couldn't get to it (even when at 2500RPM) tells me there is something going on. After restricting the return line, pressure rose and I stopped restricting at 30psi and it remained at that pressure throughout the entire RPM range. Ok, bad overflow valve. Got the new one in today and stuck it in. Pressure is now normal. 17-22psi idle, 25-35psi at 2500RPM. After getting onto the road, it was a different story. Pressure was fine until you floored it and it would reach a low of ~22psi. The overflow valve works fine, so the next thing in line is filtering. I haven't touched them in a while and I have a feeling they are not going to be pretty. After changing the main filter and cleaning the fuel heater prefilter, I will test again. If no change, we will move on to the lift pump. Should be interesting. This shows that pressure alone means nothing. We need flow too. All the test procedures say to run all the tests idling and mine is perfect, but driving needs flow. So they need to add it to their procedure. I will get the filter tomorrow and see what happens. If nothing, I will try and dig up some lift pump diagnostics. I ran a flow test at idle a couple weeks ago and got I think it was 36GPH. The lift pump is mechanical so the flow increases as RPM increases. Naturally, idle RPM will have a lower flow.
