I can't find the pigtail connector for the fuel rail pressure sensor on the back of the rail, not the FCA pigtail.  I'm done and need a direction to start with. I've searched bosch connectors and everything
Posted (edited)
used the part number lookup tool to get the pn for the sensor then google machine.
Partnumber tool.
https://mopar1973man.com/external-media/pdf/2011Ram3500parts.pdf#view=FitB&page=184
https://www.amazon.ca/Diesel-Injection-Pressure-Pigtail-Cummins/dp/B07SJM57Y7
thats up to 2012 though so you might want to cross refeence the sensor and see if it is the same on your model year.
Edited by Me78569
That's the wrong one. The one on mine is 4 wire sensor
The part number tool is the best thing I've ever seen!!!! Thank you so much
That would be fantastic if you could,  but don't go out of your way man. I'll pull mine and get the part. You said put in the part number and machine at Google that, correct?
I didn't get any returns on the sensor having a pigtail.  I was going to look at the oem plug and get a number or brand off that.
Lol. Yeah, they kinda OVER did it with all the extra plastic lol. I'm not having any luck either man. Thanks for your effort!
