- Replies 7
- Views 1.8k
Great work! 3 posts
Wildlife 3 posts
wish4hemi 1 post
My truck has no ecm plugged in and the check engine light is off and no DTCs are present which is strange not even th p1639. So the obd2 is only getting data from the pcm. The downside is the gauges d
Agreed, some of the data is questionable at best. Possibly due to the missing module on the missing VP44 fuel injection pump I contacted AutoEnginuity first. I provided the exact same in
The truck I'm working on has the Cumins 5.9 24 valve engine. My question is about the Diagnostic Trouble Codes.
I'm scanning with the AutoEnginuity, PC based scan tool, with the enhanced Chrylser / Dodge software. I've attached the DTC Report. THIS ENGING HAS HAD THE VP44 PUMP REPLACED WITH A P7100 PUMP. I know some codes are a result of that swap.
Each of the DTC "P" codes includes a description, Status, Good Trip counts, and Starts Since Failed. Each corresponds to a code that can be found in the FSM (factory service manual) as well as many other documents.
The "Freeze Frame" information is confusing. For example, on the report I 've attached, the 3 Freeze Frames are listed as:
"Freeze Frame 1 for DTC 255"
"Freeze Frame 3 for DTC 3855"
"Freeze Frame 4 for DTC 3842"
The information contained in the Freeze Frame is clear (engine speed, oil pressure, coolant temp, etc.), but the DTCs (255, 3855, and 3842) are not defined, nor are they listed in the FSM or any other document I can find.
I am seeking any information about these codes. I assume there are many more codes, but I have been unsuccessful finding any information regarding codes in this format.
99 Dodge Cummins DTC Report 04-29-23.pdf
