- Replies 2
- Views 612
Mopar1973Man 1 post
Tractorman 1 post
Popular Days
From looking at your photos, the steering shaft can only slide on to a specific position. The first photo shows a space between two sets of splines. The bolt will pass though that space when the ste
All the way in with the shaft and the bolt must line up with the rounded groove.
Hi! Finishing up the install of the Bluetop steering gear tonight and I'm second-guessing myself.
How deep should the steering shaft (I think it's called) go onto the new gear box splined input?
I attached two pics. first shows about the length of the gearbox input, and second is as far as I could shove the steering shaft onto that gearbox input spline.
Does that look like a good depth? if not, any tricks for getting it on further? It's been a bit of a battle so far.
