1992 Dodge Cummins Clutch Switch
Just aheads up if you are looking for a clutch switch, these switches are ranging from 150 to 180 dollars. Very spendy. In my case the switch was still good but who ever installed the clutch master cylinder forgot the backing washer for the switch. The clutch switch was sliding into the head of the master cylinder which prevented the starter from cranking. Mark, he found out a Poweraid cap would fit perfectly and now the switch has a backing washer. Correcting the start up issue.
  • Replies 0
Archived
  • Current Donation Goals
    • Raised $20
