- Replies 12
- Views 778
Mopar1973Man 6 posts
Jespersen79 6 posts
Popular Days
Simple remove the alternator walk into a NAPA or similar and tell them you want it benchtested make sure you ask about having it tested for AC ripple. Then if you replace the alternator test the new o
I did the W-T mod, I went with the 150amp breaker and did the fuse on the PCM while I was at it. I replaced the altenator when I got the pickup because it had a bearing noise, I used a Bosch replaceme
I recently bought a new to me 1999 2500. Low miles, 124k.
My issue I'm having is I have codes p1964, no ccd bus and the companion code. I have no wait to start or an intermittent wait to start. What I have found weird is if I unhook my grounds for 5-10 mins then reconnect them the wait to start is immediate for 3-4 key cycles, then goes back to intermittent or not at all. I found this out when I put on new military cable ends, the grounds wouldn't stay tight.
Pickup runs fine, doesn't want to start when it's super cold, which makes sense with no wait to start but when it's warm it pops right off and runs great. Also another side note I have had it start and go straight to 1000rpm but shut it off and restart it's fine. I replaced the IAT sensor and coolant sensor just because it's 25 years old, no change.
I'm planning on doing the W-T mod ASAP. But wondering if this means my ECM is toast or I have wiring issues. Just not sure where to start and all the reading is making my head hurt....
Thank you for any input!
Edited by Jespersen79
