Backup lights
I came home from work the other day to my truck in the driveway with the backup lights on.I unplugged my trailer - no short there, they stayed on. I played with my override switch and my shifter, they didn't turn off.I pull the backup light fuse and they stayed on.It seems that the hot side must be shorted to voltage somewhere after the switch on the trans. Anyone have any ideas on common bad splices or pinch points? I've got no guesses on likely areas myself, thought I'd throw it out there and see if this was any sort of "common problem" that I'd just never stumbled across.
