02 3500..torque specs and proceedure for head bolts on the cummins engine..were can I find this info? :bulb
You can find it in the Dodge FSM books... The 2001 book will work for 98.5 to 2002 trucks...
http://forum.mopar1973man.com/downloads.php?do=cat&id=2
(3) Lightly lubricate head bolts with engine oil and install. Using the sequence shown in (Fig. 30), tighten bolts in the following steps:
(a) Torque bolts to 80 N·m (59 ft. lbs.)
(b) Torque bolts to 105 N·m (77 ft. lbs.)
© Re-check all bolts to 105 N·m (77 ft. lbs.)
(d) Tighten all bolts an additional ¼ turn (90°)
  • 2 years later...
