Vibration from 4wd floor shifter
I have a very annoying vibration sound coming from the 4wd floor shifter. The noise wasn't there when I first got the truck, but I haven't done anything to cause this. The shifter feels like it's all the way forward and left in 2wd and is vibrating against the plate it goes between. When I hold it slight right the vibration noise goes away. Any ideas on how to correct this or maybe adjust the way the shifter sits?
Hmmm, found this:
http://dodgeram.info/tsb/1997/21-12-97.htm
The TSB fixed the issue. Bent the tab out about a 1/4''. :thumb1:
