Crankcase Vent Mod
Just done the crankcase vent mod w/some mods of my own. I liked the pictures of the mod but I did it a little different than what I saw. The pics. I saw showed the mod without the radiator hose which will rub against the pvc pipe when it is connected. Over time you will get a problem. If you take the 3/4" curved hose that is already on the vent to the canister you will see you can cut it to be a perfect fit to go around the radiator hose by cutting the curved part off. Put a short piece of 1/2" pvc into the hose, CLAMP IT and Attatch the 90% pvc then cut and fit the pvc to meet your needs. At the end , instead of using more pvc AS A DOWN PIPE I simply put a 3 ft. piece of 3/4" heater hose and ran it out the bottom with A ZIP TIE. Simple, works perfect, looks good. Painted it black.
