- Replies 9
- Views 2.8k
JacksonDog 4 posts
Mopar1973Man 3 posts
pepsi71ocean 2 posts
Having a little problem. I searched and didn't find an answer. I have internittent hard starts. Hard to isolate a common denominator except when parked at an angle. It always cranks extra before firing then. Other times it just does it, whether it's been sitting for awhile or just a few minutes. This is the problem that doesn't bother me too much. The other problem is there is consistantly fuel in my oil. These problems just began when I installed my new injectors. This was my first install and I took my time and follwed Mike's instructions. No big deal or problems on the install. Since then I have noticed that I have fuel in my oil. I changed my connector tube o-rings and tightened my injector hold downs. It seemed to get better, but has not gone away entirely. I posted on cummins forum and some suggested the diaphram in my VP. I also asked Jacob (whom I consider to be quite trusworthy). He also suggested the diaphram in the VP. I have scanned and got no codes. Any help would be greatly appreciated. Thanks- Patrick.
