Drain line in engine comp for AC/Heater
I remember reading some where in this forum about how to clean out subject drain line but can't locate the post now. Will someone please direct me to it or tell me what to use to clean out the line?ThanksMOHOK
  • Replies 2
  • Views 1.6k
Real simple. Just use a shop vac and put it on the outside of the drain and let it suck! The drain often gets some goop built up and the vacuum seems to work the best.
Thanks Mohok
