ABS and Brake Light
Having issues...i was dropping some calves at our local stock pen, gentleman in front of me needed a jump. Shortly there after my ABS and BRAKE lights came on and have been flashing on and off ever since. I have checked all the fuses, didnt have to replace any. ANYBODY, can you shed some light on my current situation?
  • Replies 1
  • Views 2.9k
Sure can... http://articles.mopar1973man.com/index.php?option=com_content&view=article&id=29:antilock-braking-system-abs&catid=23&Itemid=107 Now double check your fuses with a ohm meter I've found fuse that have cracked and never blown out. What happens as a load is place on the fuse it will heat up and seperate and open circuit then you get the lights then the fuse cools and connects again and light go out...
