I finally got a couple of days off, I got the intercooler repaired, put back in and drove the truck it would now make some boost if I would get on or pull a little grade, but not over 17 psi and egt's shoot up quick, so yesterday I put the boost leak tester back on and pressured it up to close to 30psi but it kept blowing the leak tester cap off, so I am sure it is pressuring up and if it has a leak it can not be very big, what else would cause very low boost and high egt's :confused:
Ok... Pressurize the system to about 15-20 PSI. Then spray the system down with soap solution looking for bubbles. Check the manifold, IAT & MAP sensors, boots, turbo, intercooler (yeah I know you got it fix but...).Then you might take the turbo off and verify the wastegate is not sticking open. Also check to make sure there is no drive pressure loss. Check you exhaust manifold, exhaust housing on the turbo and wastegate for good seal.Do you have a boost elbow??? :confused:
Can I ask a question,,,,,,,1/ how much boost should you have,,,, 2/and how do you tell what is maximum boost, by putting it to the floor and holding the accelerator to the floor, for how long?
Sure...
On a stock truck about 18-19 PSI of boost. with BOMB's it can go 35 PSI and higher. But stock turbo is only good till 35 PSI (Over rev).
Basically yes... Just stomp on it...
for how long?
About 2K to 2.5K RPM's you should see MAX Boost.
It all based on hold much fuel you can pour in the cylinders. More fueling enhancements the boost that is produced.
