Trailer Lights
I borrowed my brothers enclosed trailer and all the lights fine work except the interior lights.He says they worked the last time he used it. I'm going to try and check it out in the daylight so I haven't really dug into it yet.Any ideas...............
Well.......If I use the ground pin on the plug I get no voltage at all at any pin. If I ground to the hitch frame I've got voltage at all pins except the one that should be power.So I'm pretty sure that it's truck related.Thanks for the help.
