Map Sensor Question
I have a lift pump acting up and replacing it Wed. On the way to this morning my check engine light came on and I got an 0237 on the code reader. I read the check list on the error code page, so my question is can the map sensor just go out causing the code or is there any correlation between a bad lift pump and a map error?
