- Replies 7
- Views 2.4k
ISX 4 posts
Mopar1973Man 3 posts
I picked up a scrap P7100 a while back and just got around to destroying it to see how it all worked. One side done, need to flip it over and do the rack side, then widdle it a little more to see everything better, then work on the governor portion. I don't want it to be apart enough for it to not operate, as in parts falling out.. There is a cut away view of a P7100 floating around that everyone has seen but I want to see how it works as in operation. I will make a video of it all and show how everything works together. The pump side is pretty straight forward, it's the governor side I really want to see in operation. The theory of the governor is simplistic as well but if you look inside at the governor on these pumps you don't exactly see anything simplistic. Kinda like saying an engine works by injecting fuel and igniting it, yet pop the hood of a new car and explain where the simplicity takes place and what everything else is for..
Without further delay, here's what I got so far.
