Hooking up the starter delay relay help
I am finally getting around to doing the relay fix for my 98.5 dodge. Don't have trouble in the winter but do in the summer. In the center under the hood in a loom of wires in front of the firewall, is the hot wire going to the lift pump in these. If so it isn't yellow/white. I'm trying to find an easy place to cut it to run the wires to the relay. I can't get my fat arms and fingers to work right at the lift pump. I am still running the stock type pump, the wires at the pump are way to short. Thanks
  • Views 1.4k
No posts to show
