this spring i plan on dropping the tank out of my 02. i already have an airdog with a 1/2" draw straw but imn sick of low level slosh issues. im going to get a vulcan draw straw V. but while im at it, i wanna run 1/2" return lines too and have em dump into the canister rather than the filler neck. i was just wondering what size the banjo return fittings are? so i can put a jic fitting on the back of the head like the airdog supply. and from what ive found i need a barbed banjo fitting fo rthe return off the pump because of the pressure valve in the bolt. just dont know what size for that either.thanks
  • Replies 4
  • Views 2.2k
just driving its not bad but if you hit the brakes hard the fuel runs to the front of the tank and lift pressure drops. i dont run it below 3/8 of a tank. just havent been able to find the sizes of the fittings i need
so far i found that the one on the back of the head is 12 mm. stil not sure about the one on the vp44. i think im just gonn arun 3/8 frpom the head and the pump and then T them together into 1/2 an back to the tank.
