Heater Core Supply and return lines - sizing
Replaced my heater core lines with High temp hose & sleeved both each with a piece of heat shield. Heat shield will reflect most of the heat, cost $5 to 8 a foot. I used 3'... Dave
Yeah basically what I plan to do. What size or where did you get the heat resistant hose ........
Parker.com Or mcmaster.com would be where I'd start. Parker has local stores as well.
- - - Updated - - -
John,
Now that I am not on my phone...
Below is 1/2" parker heater hose, silicone std wall. Use this hose and put it inside the firesleeves below. Also, this stuff will work as conduit for electrical or pneumatic lines.
[TABLE=width: 100%]
[TR]
[TD=class: column_header_part_list]6722-0500050[/TD]
[/TR]
[/TABLE]
http://www.parker.com/portal/site/PARKER/menuitem.bb22d5a82bbb5b147cf26710237ad1ca/?vgnextoid=a2d9b5bbec622110VgnVCM10000032a71dacRCRD&vgnextfmt=EN&vgnextcatid=2770092&vgnextcat=HEATER%20AND%20COOLANT%20HOSE&vgnextdiv=D45361&vgnextpartno=6722-0500050&Wtky=HOSE
They also have "firesleeve" that is a bit more stout.
http://www.parker.com/portal/site/PARKER/menuitem.bb22d5a82bbb5b147cf26710237ad1ca/?vgnextoid=a2d9b5bbec622110VgnVCM10000032a71dacRCRD&vgnextfmt=EN&vgnextcatid=2770091&vgnextcat=FIRESLEEVE&vgnextdiv=D45361&vgnextpartno=6639-0750032&Wtky=HOSE
The brouchure on the firesleeve is at the below link... Rated at temps: Continuous: -65 to +500°F * Intermittent: -65 to +2000°F. Honestly, this stuff should do you, 85psi rating, 500F continous rating... If you have things under your hood over 500F you have some serious heat radiation problems and will want to heat wrap or coat the crap out of those twins.
http://www.parker.com/portal/site/PARKER/menuitem.de7b26ee6a659c147cf26710237ad1ca/?vgnextoid=fcc9b5bbec622110VgnVCM10000032a71dacRCRD&vgnextfmt=default&vgnextdiv=687563&vgnextcatid=2633653&vgnextcat=SFS+SERIES+-+SILICONE+FIRE+SLEEVE&Wtky=
Awesome awesome awesomecpl questions though1) This the correct ID and OD ? I guess I can go pull the lines off the truck and measure myself - but if u know[TABLE=width: 100%][TR][TD]INSIDE DIAMETER[/TD][TD]1/2 in. (13mm)[/TD][/TR] [TR=bgcolor: #F3F3F3][TD]REINFORCEMENT BRAIDS[/TD][TD][/TD][/TR] [TR][TD]OUTSIDE DIAMETER[/TD][TD]0.815 in. (21mm)[/TD][/TR][/TABLE]2) where do you actually order it - its talking about 50ft lenghts3) Can be used for AUTO coolant purposes ? Says glass/welding shops / foundries ....
Let me check through it and see... I'm not at my computer today. As for where to get it they usually have either Parker sales shops or Parker dealers around most industrial towns or some farm towns.
[TABLE=width: 100%]
[TR]
[/TR]
[TD][/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
Ok John, back from two solid days of wrenching back at the family farm. (the 02 is looking MUCH better though!)
1. I am not sure what the correct ID and OD is, I am pretty sure that it is likely a standard, and could be either measured or just ordered from NAPA.
2. If we look at the data sheet from the first link I posted, it looks like it is recommended for use as heater hose in cars, trucks and buses. See row 3 in the below table. Also, the Parker hose is rated to 350F by itself. Probably not too much more than the stock rubber hose, but it is a silicone hose and may cost similar if you can find a local Parker vendor.
[TABLE=width: 100%]
[/TR]
[TR=bgcolor: #010180]
[TD] DESCRIPTION[/TD]
[TD]ATTRIBUTE VALUE[/TD]
[/TR]
[TR]
[TD]PRODUCT TYPE[/TD]
[TD]INDUSTRIAL HOSE SILICONE[/TD]
[/TR]
[TD]APPLICATION[/TD]
[TD]Heater hose for cars, trucks, and buses[/TD]
[/TR]
[TR]
[/TR]
[TD][/TD]
[/TR]
[TR]
[/TR]
[TD]WEIGHT[/TD]
[TD]16.90 lbs. per 100 ft.[/TD]
[/TR]
[TR]
[TD]MINIMUM BEND RADIUS[/TD]
[TD][/TD]
[/TR]
[TD]MAX RECOMMENDED WORKING PRESSURE[/TD]
[TD]83[/TD]
[/TR]
[TR]
[TD]MAX STEAM WORKING PRESSURE[/TD]
[TD][/TD]
[/TR]
[TD]LENGTH[/TD]
[TD]50 ft.[/TD]
[/TR]
[TR]
[TD]TUBE CORE MATERIAL[/TD]
[TD]Silicone[/TD]
[/TR]
[TD]COVER MATERIAL[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]COVER COLOR[/TD]
[TD]Blue[/TD]
[/TR]
[TD]REINFORCEMENT[/TD]
[TD]High-temperature-resistant plies[/TD]
[/TR]
[TR]
[TD]TEMPERATURE RANGE[/TD]
[TD]-65ºF to 350ºF[/TD]
[/TR]
[TD]TRADE/BRAND NAME[/TD]
[TD]6722 X-treme Standard-Wall Heater Hose[/TD]
[/TR]
[TR]
[TD]BRANDING[/TD]
[TD]PARKER SILICONE SERIES 6722[/TD]
[/TR]
[TD]BRAND DESCRIPTION[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]PRESSURE RATING[/TD]
[TD][/TD]
[/TR]
[TD]VACUUM RATING[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]SAFETY FACTOR[/TD]
[TD][/TD]
[/TR]
[TD]INDUSTRY SPECIFICATION[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]FITTING STYLE[/TD]
[TD][/TD]
[/TR]
[TD]COUPLED ASSEMBLIES[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]PACKAGING[/TD]
[TD][/TD]
[/TR]
[TD]UNSPSC[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ADDITIONAL DETAIL[/TD]
[TD]STD HEATER HOSE 1/2"X 50' BLUE[/TD]
[/TR]
[TD]SYNONYM
[/TD]
[/TR]
[/TABLE]
3. The hose in the first link is the actual hose... The second links are for the fire sleeves that will add a good amount of additional insulation and protection from hot glowing metal and hot air. They won't however, keep the internal hose completely cool.
also...
I've used the fire sleeves before in race applications, and basically they are just sleeves that you run your hoses in. I think we ran fuel and air lines in them if I recall right. You may be able to even use the fire sleeve on the stock heater hose and save some money while getting pretty good heat protection...
Also, below is a list of the parker locations in NC, based from their site. I've used the parker shop near the family farm for years... Swagelok fittings, hydraulic hose, etc... but there may be a better place to find what you need. They have just worked well for me.
[TABLE=class: sortable, width: 100%]
[TR=class: even]
[TD]MEDICAL SYSTEMS DIVISION
1517 IVAC WAY
CREEDMOOR
NC
UNITED STATES
27522
457989
[/TD]
[TD][TABLE]
[TR=class: even]
[TD]Manufacturing Facility[/TD]
[/TR]
[/TABLE]
[/TD]
[TD]CREEDMOOR[/TD]
[TD]NC[/TD]
[/TR]
[TR=class: even]
[TD]GEAR PUMP DIV
101 CANTERBURY RD
KINGS MOUNTAIN
NC
UNITED STATES
28086
Ph: (704) 730-2000
Fax: (704) 730-5832
200394
[/TD]
[TD][TABLE]
[TR=class: even]
[/TR]
[TR=class: odd]
[TD]Sales Office[/TD]
[/TR]
[/TABLE]
[/TD]
[TD]KINGS MOUNTAIN[/TD]
[TD]NC[/TD]
[/TR]
[TR=class: odd]
[TD]HYDRAULIC VALVE DIVISION
203 PINE ST
FOREST CITY
NC
UNITED STATES
28043
Ph: (828) 245-3233
Fax: (828) 245-4235
687401
[/TD]
[TD][TABLE]
[TR=class: even]
[/TR]
[TR=class: odd]
[/TR]
[/TABLE]
[/TD]
[TD]FOREST CITY[/TD]
[TD]NC[/TD]
[/TR]
[TR=class: even]
[TD]INDUSTRIAL HOSE PRODUCTS DIV
465 AIRPORT ROAD
SALISBURY
NC
UNITED STATES
28147
Ph: (704) 637-1190
688929
[/TD]
[TD][TABLE]
[TR=class: even]
[/TR]
[TR=class: odd]
[/TR]
[/TABLE]
[/TD]
[TD]SALISBURY[/TD]
[TD]NC[/TD]
[/TR]
[TR=class: odd]
[TD]PRECISION FLUIDICS DIV
127 SPEEDWAY DRIVE
MOORESVILLE
NC
UNITED STATES
28117
Ph: (704) 662-3500
Fax: (704) 660-9344
400609
[/TD]
[TD][TABLE]
[TR=class: even]
[/TR]
[TR=class: odd]
[/TR]
[/TABLE]
[/TD]
[TD]MOORESVILLE[/TD]
[TD]NC[/TD]
[/TR]
[TR=class: even]
[TD]SSD DRIVES DIV
9225 FORSYTH PARK DRIVE
CHARLOTTE
NC
UNITED STATES
28273
Ph: (704) 588-3246
Fax: (704) 588-3246
688297
[/TD]
[TD][TABLE]
[TR=class: even]
[/TR]
[TR=class: odd]
[/TR]
[/TABLE]
[/TD]
[TD]CHARLOTTE[/TD]
[TD]NC[/TD]
[/TR]
[TR=class: odd]
[TD]TECHSEAL DIVISION
2600 WILCO BLVD
WILSON
NC
UNITED STATES
27893
A79696
[/TD]
[TD][TABLE]
[TR=class: even]
[/TR]
[/TABLE]
[/TD]
[TD]WILSON[/TD]
[TD]NC[/TD]
[/TR]
[TR=class: odd]
[TD]KIT DIVISION
125 EAST MEADOWVIEW ROAD
GREENSBORO
NC
UNITED STATES
27406
687321
[/TD]
[TD][TABLE]
[TR=class: even]
[/TR]
[TR=class: odd]
[/TR]
[/TABLE]
[/TD]
[TD]GREENSBORO[/TD]
[TD]NC[/TD]
[/TR]
[TR=class: even]
[TD]NYCOIL
164 POINTE SOUTH DR
RANDLEMAN
NC
UNITED STATES
27317
660932
[/TD]
[TD][TABLE]
[TR=class: even]
[/TR]
[/TABLE]
[/TD]
[TD]RANDLEMAN[/TD]
[TD]NC[/TD]
[/TR]
[TR=class: even]
[TD]FILTRATION AND SEPERATION
DOMNICK HUNTER
5900-B NORTHWOODS BUSINESS PLW
CHARLOTTE
NC
UNITED STATES
28269
Ph: (704) 921-9303
Fax: (704) 921-1960[/TD]
[/TR]
[/TABLE]
