- Replies 8
- Views 2.8k
Mopar1973Man 4 posts
Howie67 4 posts
I have a centrifuge that uses a small air pump to push the oil up to the fitting going through the oil fill cap. I also have a edge juice that has a turbo cool down timer i have set at 300. I have the pump set to key on power from inside on the aux circuit. That is dead when the cood down is working with the key off. I was thinking i could move the power which energizes a relay for the pump to come off the alt but am unsure if the alt has a dc power signal that is only active when the eng is running so it will turn off the pump after the eng stops turning but stay on with the key off and end running so the centrifuge will continue workng while it is cooling down.Thanks, Curt
