So, my '97 3500's airbag light is on. I assumed it was the clockspring, as that is a common issue that I've experienced in the past. I ordered a new one, and it arrived yesterday.Last night, I pulled the steering wheel. Low and behold, the clockspring was trashed..So, I replaced it with the new one.Started the truck up, AIRBAG light comes on, then goes out!!...Then came back on and stayed on.. :mad:Dagnabbit.. I need this fixed so I can get the truck inspected.. I printed off the wiring diagram, and the device components are pretty straight-forward:control moduleleft sensorright sensorclockspringdash lightIIRC, the airbag is 2ohm resistance.. Can anyone verify that? I'd like to place a 2 ohm resistor in place of the airbag plug, to isolate whether or not it is clock-spring/airbag related, or module/sensor related..Any help is appreciated..
  • Views 1.3k
