Install/Uninstall errors 1500
Well gang... Here is my last delimma... My Win Vista system has been running flawless for a ong time till... Error 1500 was been displayed all the time I tried to install of un-install a piece of software. There is a few causes...1. Make sure there is no other installations running. 2. Check the registry for a stuck enty pointing to a busy install. 3. Temp folder is corrupt. Well it came down to just killing my Win Vista and installing over again. It didn't seem to be any of the above problems. But it was a sure a registry problem of some sort. Nop matter what I used to check the registry it still never found the bad entry.. So here I'm back on the air but in limited means...:neutral:
  • Views 1.4k
No posts to show
