The truck fell flat on her face, dead pedal. got a 0237 code. Checking out the forums I've seen the code called Map sensor, Boost sensor, Turbocharger sensor. I just want to confirm that they are all one in the same. I found the part on Rock Auto's website for $200 just want to make sure it is the right part. Or if anyone knows where to get it for less. Also, I've done the adjust APPS to correct voltage. Is this just a patch till the inevidible and should just be replaced? Thanks.'02 HO 3500 6sp airdog, mbrp, edge w/att, aem intake.
Thanks Mpoar Man, I see you help out a lot of us poor saps. Your help is appreciated. I live in Canada so our parts are way over priced. I use Rock auto quite a bit. But I'm working in Buffalo right now so I'll check the dealer cost here.
