cummins/ECM plug ?
Has anyone repaired a terminal on the female side of the plug. Deustch connector. I have looked @ the website but I didn't find the repair of that 50 pin connector.
I'm not sure what website you are talking about. You should try quickserve, you will need your ESNnumber of the engine tag. https://quickserve.cummins.com/info/index.html Sent from my DROID BIONIC using Tapatalk 2
