I did get it started, I jumped the terminals on the starter ('00 3500). Funny how you check to make dang sure it's in N before crawling under the truck... and still a little nervous when you stab the terminals with piece of baling wire..So, tomorrow, will check the fuse, relay, and the clutch safety switch... anything else?
