Posted (edited)
P0016 engine speed signal mismatchp0071 inlet air temp sensor rationalityp0072 inlet air temp sensor voltage too lowp0073 inlet air temp sensor voltage too highp0088 fuel rail pressure signal is above max limitp0106 inlet air pressure sensor rationalityp0107 inlet air pressure sensor voltage too lowp0108 inlet air pressure sensor voltage too highp0111 intake air temperature (iat) sensor rationalityp0112 intake air temperature (iat) sensor voltage too lowp0113 intake air temperature (iat) sensor voltage too highp0116 engine coolant temperature (ect) sensor rationalityp0117 engine coolant temperature (ect) sensor voltage too lowp0118 engine coolant temperature (ect) sensor voltage too highp0128 thermostat rationalityp0148 high pressure common rail (hpcr) checksump0169 water in fuel (wif) light on too longp0192 fuel pressure sensor voltage too lowp0193 fuel pressure sensor voltage too highp0201 injector no. 1 control circuitp0202 injector no. 2 control circuitp0203 injector no. 3 control circuitp0204 injector no. 4 control circuitp0205 injector no, 5 control circuitp0206 injector no. 6 control circuitp0217 decreased engine performance due to engine overheat conditionp0219 crankshaft position sensor over speed signalp0234 turbo boost limit exceededp0236 map sensor too high too longp0237 map sensor voltage too lowp0238 map sensor voltage too highp0251 cp3 pump regulator controlp0300 multiple cylinder misfirep0301 cylinder no. 1 misfirep0302 cylinder no. 2 misfirep0303 cylinder no. 3 misfirep0304 cylinder no. 4 misfirep0305 cylinder no. 5 misfirep0306 cylinder no. 6 misfirep0335 crankshaft position (ckp) lostp0336 crankshaft position (ckp) sensor signalp0337 crankshaft position (ckp) sensor voltage too lowp0338 crankshaft position (ckp) sensor too highp0340 camshaft position (cmp) lostp0341 camshaft position (cmp) sensor signalp0381 wait to start lamp inoperativep0461 fuel level unit no change over timep0462 low voltage detected at the fuel level sensorp0463 high voltage detected at the fuel level sensorp0477 low voltage on the engine brake driverp0478 high voltage on the engine brake driverp0480 fan clutchp0483 fan speedp0500 no vehicle speed sensor signalp0514 bat temperature sensor rationalityp0516 low voltage at the bat temp sensorp0517 high voltage at the bat temp sensorp0521 oil pressure switch rationalityp0524 oil pressure to lowp0532 a/c sending unit volts too lowp0533 a/c sending unit volts too highp0541 low voltage on the no. 1 intake air heater relayp0542 high voltage on the no. 1 intake air heater relayp0562 battery voltage lowp0563 battery voltage highp0572 low voltage detected at the brake switchp0573 high voltage detected at the brake switchp0580 low voltage detected at the cruise control switchp0581 high voltage detected at the cruise control switchp0602 checksum errorp0604 ecm software errorp0606 ecm hardware errorp0607 ecm internal failurep0622 generator field not switching properlyp0628 low voltage detected at the fuel lift pumpp0629 high voltage detected at teh fuel lift pumpp0630 vin not entered errorp0633 skim secret key not enteredp0642 low voltage at the no. 2 sensor supply circuitp0646 low voltage detected at the a/c clutch relayp0647 high voltage detected at the a/c clutch relayp0652 low voltage at the no. 1 sensor supply circuitp0653 high voltage at the no. 1 sensor supply circuitp0698 accelerator position sensor (app) supply voltage too lowp0699 accelerator position sensor (app) supply voltage too highp0700 transmission messagep0711 (2) transmission temperature sensor performancep0712 (2) transmission temperature sensor lowp0713 (2) transmission temperature sensor highp0720 (2) output speed sensor errorp0743 (2) torque converter clutch solenoid/trans relay circuitsp0748 (2) pressure sol control/trans relay circuitsp0751 (2) o/d sol performancep0753 (2) trans 3-4 shift sol/trans relay circuitsp0836 (2) 4wd mux switch stuckp0837 (2) 4wd switch performancep0838 (2) 4wd mode sensor lowp0839 (2) 4wd mode sensor highp1652 j1850 short to groundp1740 (2) tcc o/d sol performancep1756 (2) gov press not equal to target @ 35-40 psip1757 (2) gov press above 3 psi in gear with 0 mphp1762 (2) gov press sen offset volts too low or highp1763 (2) governor pressure sensor volts too highp1764 (2) governor pressure sensor volts to lowp1765 (2) trans 12 volt supply relay ctrl circuitp2121 app volts do not agree with idle validation signalp2122 low voltage at the app sensorp2123 high voltage at the app sensorp2127 low voltage at the throttle validation switchp2128 high voltage at the throttle validation switchp2146 bank 1 (cylinders 1-3) shorted high or lowp2149 bank 2 (cylinders 4-6) shorted high or lowp2266 water in fuel (wif) sensor voltage too lowp2269 water in fuel (wif)p2502 charging system errorp2503 charging system low errorp2504 charging system high errorp2509 powerdown data lost errorp2607 low voltage at the no. 2 intake air heater relayp2608 high voltage at the no. 2 intake air heater relayp2638 (2) torque management feedback signal performance
Guest
This topic is now closed to further replies.
