Anyone familiar with Cummins Quick Serve site??
- Replies 3
- Views 3k
Wild and Free 1 post
rotory26 1 post
rancherman 1 post
I joined up mainly to explore parts for my Cummins 903, It did recognize my ESN!
When I click on parts under my ESN, I'll get this screen:
[TABLE=class: fullscreen]
[TR]
[TD]
[TABLE]
[TR]
[TD]
[TABLE]
[TR]
[TD]
Content For Engine Serial Number (ESN): 10966569
PRINT OPTION LIST
[TABLE=class: box, align: center][TR]
[TH=class: tbl_header, colspan: 2]Archive Option Information
[/TH]
[/TR]
[TR]
[TH]Part Number
[/TH]
[TH]Description
[/TH]
[/TR]
[TR]
[TD]156172
[/TD]
[TD]FILTER, FUEL:
[/TD]
[/TR]
[TR=class: even]
[TD]173772
[/TD]
[TD]SUPPORT, FRONT MOUNT:
[/TD]
[/TR]
[TR]
[TD]189559
[/TD]
[TD]CONNECTION, W.O.R.B:
[/TD]
[/TR]
[TR=class: even]
[TD]190846
[/TD]
[TD]MANIFOLD, EXHAUST:
[/TD]
[/TR]
[TR]
[TD]190847
[/TD]
[/TD]
[/TR]
[TR=class: even]
[TD]195327
[/TD]
[TD]DAMPER, VIBRATION:
[/TD]
[/TR]
[TR]
[TD]196933
[/TD]
[TD]CONNECTION, WATER INLE
[/TD]
[/TR]
[TR=class: even]
[TD]198786
[/TD]
[TD]PULLEY, WATER PUMP:
[/TD]
[/TR]
[TR]
[TD]201654
[/TD]
[/TD]
[/TR]
[TR=class: even]
[TD]202046
[/TD]
[TD]BELT, FAN:
[/TD]
[/TR]
[TR]
[TD]203170
[/TD]
[TD]LINER, CYLINDER:
[/TD]
[/TR]
[TR=class: even]
[TD]204586
[/TD]
[TD]THERMOSTAT:
[/TD]
[/TR]
[TR]
[TD]208437
[/TD]
[TD]CONNECTION, AIR INTAKE
[/TD]
[/TR]
[TR=class: even]
[TD]209768
[/TD]
[TD]HOUSING, GEAR COVER:
[/TD]
[/TR]
[TR]
[TD]212020
[/TD]
[TD]PISTON:
[/TD]
[/TR]
[TR=class: even]
[TD]215580
[/TD]
[TD]CAMSHAFT:
[/TD]
[/TR]
[TR]
[TD]215631
[/TD]
[TD]PULLEY, CRANK:
[/TD]
[/TR]
[TR=class: even]
[TD]258264
[/TD]
[TD]FILTER, WATER:
[/TD]
[/TR]
[TR]
[TD]299670
[/TD]
[TD]FILTER, LUBE:
[/TD]
[/TR]
[TR=class: even]
[TD]3004969
[/TD]
[TD]PUMP, FUEL:
[/TD]
[/TR]
[TR]
[TD]3005446
[/TD]
[TD]MANIFOLD, AIR R.B:
[/TD]
[/TR]
[TR=class: even]
[TD]3005704
[/TD]
[TD]COOLER, LUBE OIL:
[/TD]
[/TR]
[TR]
[TD]3005866
[/TD]
[TD]PAN, OIL:
[/TD]
[/TR]
[TR=class: even]
[TD]3006766
[/TD]
[TD]MANIFOLD, AIR L.B:
[/TD]
[/TR]
[TR]
[TD]3006769
[/TD]
[/TD]
[/TR]
[TR=class: even]
[TD]3007465
[/TD]
[TD]INJECTOR:
[/TD]
[/TR]
[TR]
[TD]3009584
[/TD]
[TD]PUMP, LUBE:
[/TD]
[/TR]
[TR=class: even]
[TD]3012675
[/TD]
[TD]HUB, FAN:
[/TD]
[/TR]
[TR]
[TD]3013497
[/TD]
[TD]SET,UPPER ENGINE GASKE
[/TD]
[/TR]
[TR=class: even]
[TD]3013498
[/TD]
[TD]SET,SINGLE HEAD GASKET
[/TD]
[/TR]
[TR]
[TD]3013603
[/TD]
[TD]HOUSING, THERMO R.B:
[/TD]
[/TR]
[TR=class: even]
[TD]3014149
[/TD]
[TD]RINGS, PISTON:
[/TD]
[/TR]
[TR]
[TD]3014458
[/TD]
[TD]SET,LOWER ENGINE GASKE
[/TD]
[/TR]
[TR=class: even]
[TD]3018259
[/TD]
[TD]TUBE, FUEL SUPPLY:
[/TD]
[/TR]
[TR]
[TD]3020759
[/TD]
[TD]BRACKET, FAN:
[/TD]
[/TR]
[TR=class: even]
[TD]3023111
[/TD]
[TD]ROD, CONNECTING:
[/TD]
[/TR]
[TR]
[TD]3023599
[/TD]
[TD]GAUGE, OIL LEVEL:
[/TD]
[/TR]
[TR=class: even]
[TD]3024737
[/TD]
[TD]FLYWHEEL:
[/TD]
[/TR]
[TR]
[TD]3025841
[/TD]
[TD]HOUSING, FLYWHEEL:
[/TD]
[/TR]
[TR=class: even]
[TD]3302880
[/TD]
[TD]BREATHER:
[/TD]
[/TR]
[TR]
[TD]42337
[/TD]
[TD]PILOT, SPACER:
[/TD]
[/TR]
[TR=class: even]
[TD]4851
[/TD]
[TD]GEAR, RING:
[/TD]
[/TR]
[TR]
[TD]AR10035
[/TD]
[TD]BLOCK, CYLINDER:
[/TD]
[/TR]
[TR=class: even]
[TD]AR10547
[/TD]
[TD]DRIVE, ACCESSORY:
[/TD]
[/TR]
[TR]
[TD]AR11171
[/TD]
[TD]HEAD, CYLINDER:
[/TD]
[/TR]
[TR=class: even]
[TD]AR12637
[/TD]
[TD]TURBOCHARGER:
[/TD]
[/TR]
[TR]
[TD]AR3556
[/TD]
[/TD]
[/TR]
[TR=class: even]
[TD]AR5664
[/TD]
[TD]PUMP, WATER:
[/TD]
[/TR]
[TR]
[TD]BM69973
[/TD]
[TD]VALVE, F.P.S.O:
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD]© 2000-2013 Cummins Inc., Box 3005, Columbus, IN 47202-3005 U.S.A.
Terms of Use and Disclaimers | Feedback / Help | Recommended System Requirements
Then, when I click on 'injectors', for example, I'll get this screen:
Part Number Supersessions
[TABLE=class: box]
[TR]
[TD=class: tbl_header, colspan: 7]Part Number Supersessions
[/TD]
[/TR]
[TR]
[TD=class: col_header]Part Number
[/TD]
[TD=class: col_header]Part Topic
[/TD]
[TD=class: col_header]Bulletin
[/TD]
[TD=class: col_header]Literature
[/TD]
[TD=class: col_header]Recon Equivalent
[/TD]
[TD=class: col_header]Fleetguard Xref
[/TD]
[/TR]
[TR]
[TD=align: right]+AR-40173
[/TD]
[TD=align: center][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD=align: right]+3003955
[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD=bgcolor: yellow, align: right]*3007465
[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD=align: right] 3054204
[/TD]
[TD][/TD]
[TD][/TD]
[TD]3054204PX
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[/TABLE]
The part number at the bottom of the list is the most current part number.
The part number in yellow is the part you searched.
Recon Equivalent parts may be added to the shopping cart by clicking on the Recon Equivalent part number.
To Check for a cross-reference between a Cummins part number and a Fleetguard part number, click on the V
[/TD][/TR]
[/TABLE]
I think this means that the original part (in yellow box) has been superseded by the lower part #. When I click on THAT number, it will take me to the exploded view of that particular #.
Do I have it right?
