Wait, it has its own engine? I was kinda confused how the system works. I've seen it before but its been a while since then.
It is basically a fan, a glow plug, and a fuel injector. The kit comes with a little electric pump for fuel. I plan to get one for my camper when I get a nicer camper and actually use it more. I had planned to actually use a boat fuel tank and run the power from a 110 outlet through a converter for 12 volts, never checked if they make a AC voltage version. It takes about 10-15 minutes to get it fired up and running when the fuel system is dry to get to full heat output. With a minimally insulated sleeper (approximately 322 sq. ft.) and a small BTU version for a semi I have witnessed the cab temp go from 30 to 60 in about an hour. I'm not sure but I think that truck had the smallest BTU version made installed in it. http://www.espar.com/videos/airtonic-tech-info.html
