Performace Diesel Parts + New Toyota Offering
Sale Ends August 31st 2013
Diesel Auto Power is proud to announce that we stock Extreme Head Studs for Dodge, Ford 6.0L and Chevy.
Extreme Studs are made from a fine grain, hi-strength - 240k tensile tool steel H13 specifically designed for heavy duty, hi-shock applications (DIESELS). Compare to other studs that sell near $1000. Prices Start at $610
Extreme Studs
DODGE CUMMINS
Diesel Auto Power offers a full line of replacement and performance injectors for 1989-2013 Dodge. DAP's new nozzles are EDM then extrude honed and matched at 1500PSI using calibration fluid. SAC and VCO nozzle styles avaliable.
Brand New Bosch Motor Sports 2003-2007 Injectors
Starting at $350 + core
Quality Reman from Industrial Injection 2003-2004, 2004.5-2007, 2007.5-2012
$271 + core
Performance 98-02 24v Injectors Choose 50-350HP
Coupon Code: DAP5 for 5% off
Performance 94-98 12v Injectors
Performance 89-93 12v Injectors
Performance 98-02 24v Nozzles
Performance 94-98 12v Nozzles
Throttle Position Sensor / APPS 1998-2004 (Fits Auto or Manual) $175
94-02 Cummins/Jacobs Exhaust Brake kit - Vband Connection Only
$550
8% OFF with Coupon: TRANS
DTT Billet Flex Plate For 94-07 Dodge 5.9L Cummins
GM Governor Pressure Solenoid Conversion for Dodge 47RE
GM Governor Pressure Solenoid Conversion for Dodge 48RE
TCS Billet Input Shaft for 47RH 47RE 48RE transmission 300
CHEVY/GM DURAMAX
Genuine BOSCH Injectors
Too low to advertise
Call to order
801-927-4600
LB7 2001-2004 0986435502
LLY 2004.5-2005 0986435504
LBZ 2006-2007 0986435521
LMM 2007.5-2009 0986435520
BD Exhaust Manifold Chevy Duramax Diesel 6.6L 01-10 - $250 after coupon
Coupon:BDMAN
FORD POWERSTROKE
7.3L Custom 6 Position Chip 1994-2003. Add up to 140HP $289
Compressor wheel upgrade + $55
Set of 8 Performance injectors and 6 position tuner Starting at $1425
1998.5-2003 Compressor wheel and Boost Actuator upgrade $175 = More Boost/ Less Surge
1047511 Performance turbo for 1999-2003 7.3L 88mm compressor (30% more flow) $997.50
Snow Tow Max Water Methanol Kit $750
Coupon: TOWMAX
Snow MPG Max Water Methanol Kit $850
Coupon: MPGMAX
TOYOTA
The Bully Dog GT Tuner for Toyota will be the first tuning device available for Toyota. The GT T+ will offer increases in power, fuel economy and performance as well as a huge number of monitoring capabilities that will let drivers know exactly how well their vehicle is performing.
‘07-’13 Tundra
‘07-’13 Tacoma†
‘10-’12 4Runner
‘08-’13 Land Cruiser
‘08-’10 & ‘12-’13 Sequoia
‘08-’13 Lexus LX570
†4.0L Tacoma (non-supercharged) only supports 2009-2011
More Info
MAXIMUM POWER GAINS
• Up to 25Hp and 30 ft.-lbs. of Torque
  • Views 1.2k
