Diesel coolant additive???
Before I am going to do thermostat replacement as started to sticky a little but I will do flush whole coolant as green coolant. I am wonder do I need diesel coolant additive as ford motorcrafts has one? I has four green motorcrafts coolants to use as flush old green coolant out.
My cummins has green coolant since I bought it and from 2002 and older cummins are green coolant while Chrysler and cummins had changed from green coolant to HOAT after 2003.
- - - Updated - - -
I did compare the mopar ms7170 and ford motorcrafts green coolant while ford said it is meets or exceed the requirement of Chrysler ms7170.
Motorcrafts green is ethylene glycol-based.
