sport lead light conversion
I am thinking about the pros and cons of doing this conversion using heavy duty wire and relays.Have any of you done this conversion?There is a lot of information on other forums,I have to do some thing if I am going to do much night driving. I'd appreciate any of you suggestions.
Thanks
Art
I did it 2 years ago and have no regrets, I bought the HD wiring harness (from suvlights.com) that runs direct off batteries w/ relays. The harness makes it so you can utilize both sets of hi/lo bulbs (9004 & 9007) they throw a lot of light, plus you can use what ever bulb you want. I considered Hid"s ,I'm not real fond of, i think they are overrated,
Thanks for your replies .I've decided to build my harness using the diagrams on rburks post.I've a lot of
wiring harnesses,and being that someone else has done all the design on it I'd be crazy not to take advantage of it.I' let everybody know how it tuns out.Thanks
Art.
Edited by hodag56
Thanks for you replies.I've decided to build my own harness,using the schematics from rburks post of 5 jan.
2011.It looks good and everyone seems satisfied that has used it.It woul be very easy to change the
sequence of how the ligts operate if iwas't happy with it.
Thanks Art
