Swapping a 518 for a 47rh. few small questions
hey guys its been a while since ive been on the forum. unfortuneatly my truck is off the road. i have a firend who recently purchased a 12 valve and is paying me since i have a back round with first gens to swap a 47RH into in. he used to have the old clapped out A518 in it.
i recently got the transmission completely out. a few questions i had were
does anyone know the engine adapter plate to motor torque spec for the bolts?? i found for a manual the spec is 35ft/lb but i dont know if that applys to an auto to
also i need the torque spec for the flywheel to crank
ok and the last thing.....when i was removing the metal trans lines from the trans, of course the flares wouldn't come out. so i ended up cutting the metal lines to the trans. i plan on having metal braided stainless lines made up at a hydraulic shop near by. i noticed that there are two sets of metal lines though. one set goes to the cooler core mounted up front the other set goes to some kind of cylinder on the block under the turbo. my question is basically is there any way / can i delete that cylinder???  a friend that works at a trans shop told me i could but i wanted to check with actual cummins guys before i touch it
thanks in advance NICK
The one on the side of the block is a heat exchanger it helps warm the tranny oil in the winter and helps keep it cooler in instances where the tranny oil is higher than the engine coolant temp thus the name of heat exchanger the one up front is a cooler. and yes if you want the one on the side of the block could be eliminated if need be. But it is all in series so there are not two sets of lines per say just a few in a line, flow goes out tranny to exchanger from there to cooler and back directly to tranny from cooler.
The adapter torques should be the same no matter what tranny is hanging off the back.
awesome thanks WILD and FREE. im thinking hes going to want to delete it. because i dont really thing in PA the winters are cold enough to justify it. plus its going to be more of a fun truck than anything else i beleive. so if i do delete it that trans cooler up front just aint going to cut it. do you think somethink like a B&M 12x12 cooler would do it? possibly with a fan if need be?
