FASS filter cross reference
First off I'd like to give a huge shout out to Holiday gas station for their awesome "winter blend" diesel fuel, which actually is more like a gell. While I was getting ready for work this morning, the truck was running in 3cy. mode and started to spudder, by the time I could get out to it, it was to late. So while I'm sitting here waiting for the sun to come up, I decided to poke around the FASS webisite and found a filter cross reference chart for both fuel filter and water separator, and I thought I'd share the info with you all in case you ever find yourself in a bind like I'm in this morning.  http://www.fassride.com/shop/replacement-parts/replacement-filters.php#hd_tab
 For the FASS Gun Metal Gray Titanium series pumps these are the filters according to FASS that will cross reference with their part numbers.
          http://www.fassride.com/tinymce/filemanager/files/Filters.pdf
 For the fuel filter FWS-3003 thead size 1-14 ( micron rating)
  Baldwin BF7633 (2m)
  Carquest 86528 (2m)
  CAT 1P2299 (6m)
  Donaldson P550625 (3m)
  Donaldson P551025 (4m)
  Donaldson P551311 (3m)
  Donaldson P551313 (3m)
  Donaldson P553203 (3m)
  Donaldson P557440 (6m)
  Fram P8334 (2m)
  Hastings FF1079 (2m)
  Wix 33352 (6m)
  Wix 33528 (2m)
  Wix 33674 (2m)
For the water separator FS-1001 thread size 1-14 (micron rating)
 Baldwin BF1258 (10m)
 Baldwin BF1214
 Baldwin BF7546 (10m)
 Donaldson P558000 (20m)
 Donaldson P551000 (10m)
 Donaldson P551001 (10m)
 Fleetguard FS1282 (14m)
 Fleetguard FS-1000 (10m)
 Fleetguard FS-1001 (10m)
 Fleetguard FS-1009 (14m)
 Fleetguard FS-1212 (14m)
 LuberFinder LFF8011
 LuberFinder LFF8000
 Motorcraft FD818 (14m)
 Wix 33405 (14m)
 Wix 33522 (10m)
 For the FASS Blue Titanium Series pumps the fuel filters are the same as the Gun Metal Gray Titanium series pumps, as long as your original FASS fuel filter part number was FWS-3003.
             http://www.fassride.com/tinymce/filemanager/files/Blue%20Base%20edited.pdf
 The Blue series pumps have a different water separator and thread size.
 Water separator FS-2001 thread size 3/4-16 (micron rating)
  Baldwin BF 1275 (10m)
  Donaldson P550550
  Fleetguard FS-19594 (20m)
  Fleetguard FS-19768 (144m)
  Wix 33616 (20m)
  Wix 33790 (140m)
 For the FASS HD series pumps http://www.fassride.com/tinymce/filemanager/files/hd.pdf
