Nv4500 4th gear noise
I have a nv4500 that is making a noise in 4th gear when slowing down between 1000-1300 rpms it was rebuilt 2k miles ago it has a southbend clutch its not a grinding or clunk sound more like a bearing ? Could it also be the harmonics in that gear when slowing down ? My damper wobbles a little need help !!!
Damper shouldn't be an issue.
4th gear is straight through... and SOMETIMES, the countershaft will 'rattle' around when the harmonics and the stars align..
Is the noise with foot totally off the throttle? are you braking, or coasting? Rolling as slow as 1000-1300 rpm in 4th is getting pretty 'luggy'.
Can you describe the noise more of a whirring or whining type sound?.... or more of a chirping/grunting type?
