Vehicle: Testing 1, 2, 3 (2005)
Cowboy
Name: Testing 1, 2, 3 (2005)
Date Added: 17 January 2015 - 07:16 PM
Owner: Cowboy
Short Description: 2005 Ram 3500 Quad Cab, Long Box, SRW, SLT, 4x4 Built 10/04; In Service 11/04 Bought Nov 2007 with 10,307 miles As of 07/02/14 has 100,000 miles and 3004 hours Drivetrain Cummins 600 NV5600 NV271transfer case Engine Mods Built by Big Twin Diesel 12/13 Smarty S06 PoD UDC, tuned by me Garrett Stage 2 GT3782R Balanced Rotating Assembly Hamilton Cam's 178/208/110 Hamilton 103# Valve Springs Hamilton 24V HD Pushrods Cummins 24V 1.3" tappets QSB 480 Pistons BBi Stage 1 MY03 Injectors ATS 2-piece Exhaust Manifold ARP Series 2000 Head Studs Fluidampr Southbend Con-OFE Southbend Hydraulics Jacobs Exhaust Brake Turbo Performance Products Exhaust Manifold/Turbo Blankets Airaid Modular Intake Tube GDP Flo-Pro Intake Horn GDP Air Boss Intake Plenum GDP Grid Heater Delete (MAY-SEP) GDP Big-Line Kit DT Pro Fab Steering Box Brace Kitty MIA Donaldson 40” M085171 MegaCab tailpipe w/ Resonator Home Depot CAI/WAI Gauges ISSPRO EV2's Gauges w/ warning lights -Boost (>38 psi) -EGT (>1250°) -Fuel Pressure (<3 psi) -Exhaust Brake/Drive Pressure (>65 psi) -Oil Pressure (<15 psi) Ultra Gauge EM Standard Page -Load -Rail Pressure -TPS -ECT -IAT (pre-turbo) -IAT (intake manifold) Filters and Fluids Engine -Mopar 4" Pleat OEM Air Filter -Valvoline Premium Blue 15w-40 (for motor break in) -Donaldson ELF7349 Full-Flow -Amsoil EaBP110 Bypass Filter mounted on a BMK-11 Trans -Amsoil MTF 5w-30 Xcase -Amsoil ATF Diffs -Amsoil SVG 75w-90 Power Steering/Brake Hydraulics -Amsoil ATF Coolant -Final Charge Extended Life 50:50 -Donaldson ECF4085 Coolant Filter Fuel Filtration -Baldwin BF1212 -Mopar Severe Duty Filtration Kit, with heater and WIF sensor wiring (not enabled in ECM yet) -Baldwin PF7977 OE Style 5um filter -Donaldson P551313 3um Fuel Filter, Mounted to the GDP Horn Suspension Top Gun Customz 1” Front Level Firestone Ride-Rite Rear Airbags Rear Hellwig Anti-Sway Bar Dynatrac Pro Steer Ball Joints Yukon Spin Free Hubs, with Yukon Lockouts Bilstein 5100's MAXX Links Sway Bar links Wheels/Tires 245/70R19.5 M608z LRG on Black Vision Type 81 Heavy Haulers with Counteract Balance Beads 255/80R17 LRE BFG KM2’s on OEM Forged Alum wheels (hunting tire) Do-Dads SiriusXM OynX Satellite Radio ViAir 450C compressor Cobra 75WX-ST CB Weather Guard Tool box Mopar Running Boards Mopar Vent Visors Fender Flares Garmin Nuvi 1200 Garmin eTrex Vista C Mopar Winter Front Max Brake Hydraulic over Electric Brake Controller Titan Class V Receiver Brite Box with Fog Light Control and Fogzilla Sears Platinum P-2 Batteries Mag Hytec Front/Rear Diff Covers Fast Coolers OEM Clear Cab Lights Duraflaps Geno's Console Cup Holder Current Dyno 415/850 Smarty Jr UDC, PoD99 (8/4/12) Usage Stats 40453.png Best MPG: 21.54 Avg MPH: 33.4
View Vehicle
