nv5600 synchronizer ring springs
anybody ever see or have these installed?
http://www.ebay.com/itm/271635496536?ssPageName=STRK%3AMEBIDX%3AIT&fromMakeTrack=true
Gearing up (ha ha) to start the freshening of my nv5600 for the project truck... and stumbled across these heavier than oem springs for the synchronizer rings. Supposed to make the rings more aggressive at speeding up or slowing down the required gear for engagement.
Seems like when you 'add' pressure in a certain spot, problems could surface elsewhere..
I think this would be good for the speed shifting crowd, and when shifted 'normally'.. could help add life to these very expensive rings..
Boy.....
Those springs coupled with a short throw shift tower could be a mean set up. That is probably my only complaint about the NV5600. It takes some time in between shifts. If it really would help the synchros last longer, then $27 is a cheap bill.
LOL,  I ordered them  yesterday.  Only because  when  I  get around to  building my  trans,  I'll never find the  page again!
This site'll be long gone  when I get started, so   keep an eye out  on  Tom's!
