Vacuum Line Diagram
Does anyone have a parts breakdown or diagram of the vacuum lines?  All of my vacuum line fittings are dry rotted and I want to replace all of them. I'm going to call the dealer today but in the past they always seem to be a little lost when it comes to the diesel trucks.
1999 Dodge's are pretty simple.
Vacuum goes from the vacuum pump to the cowling. Then routes over to the passenger side for HVAC controls. There should be a second line that heads down to the transfer case. If you have a exhaust brake then you could have a 3rd port on the passenger side for the exhaust brake. Routing and tubing is up to you. I would be really worried about getting factory parts. I would look at where the tubing is routed and run new rubber hose or plastic line. Most of all this stuff could be had a NAPA store. Like on my 1996 Dodge I was cheesy and bought cheap vinyl tubing and replaced all the plastic tubing. This time a around I'll most likely do Air Brake line and a bit of rubber for nipples. Re do the entire routing because I think I can do better.
Great minds think alike. I had some scrap air brake hose at the shop that worked just fine. I picked up the flexible connectors at Advance Auto.
Moved authors remarks outside the quote
