hooking up tach on a 93
1st Gens come with a computer. It's typically mounted behind the battery. The connection for the tach is typically under the dash. I've only seen one truck with the optional tach but never really look to see what wires and what colors. So if you missing the computer, crank sensor, and wiring then I'm no sure what to say...
This is why I suggest getting a aftermarket tach it would be much easier.
