DIY Hotrod Power Steering Pump
(3 reviews)
First off this can all easily be done in the truck, took me about 30 minutes the first time.
Unscrew the output line, this will also empty the resivoir, so flushing the system at the same time would be a good idea.
Then unscrew the fitting the output line screws into.  Here you can see the order of the things coming out, and should go back in.  In the picture the pressure relief valve is dissasembled, so it will only be one piece.
PS_Pump_003.jpg.19cde73404b30372b84a0ad3
To mod the pump, drill the hole through the center of the plug out larger, stock is about .125" if I remember correctly.  I drilled mine out to .2" and it made a very noticable difference in the ease of steering.  There is also a hole out the side, I drilled another .125" hole on the oposite side.  And then as the second picture shows, there is a small hole in the side of the fitting, don't plug it when you drill through the hole it leads too.
PS_Pump_057.jpg.70a2c0fc8d3d080c0cbb3ac5
screenshot_125.png.7de95d1c888c3ffc759ea
There is also a pressure relief valve inside the pump, I would not recommend monkeying with it as it only comes into effect at full lock, or when you can hear the PS pump working hard to turn the wheels.  If you still want to adjust the valve, DO NOT shim it.  Stock the plug in the valve isn't totally seated, so you can just take it out, clean it up, and then seat the plug.  Seating the plug will increase the max pressure.  Increasing the pressure only effects the max steering/braking assist.  Increasing the pressure unneeded only raises the chance of carnage.
Carnige.jpg.e24101c86e0c2f870cb0bd530cc2
To take apart the valve, here's a handy trick I found, take care not to ruin the machined surfaces!
PS_Pump_043.jpg.902087326407e8f93c456d42
Here's the plug taken apart, notice the shim in the picture, this shim is not stock, and after testing, would render the pressure relief valve useless.
PS_Pump_006.jpg.df1b3ebe58d9d5e9e62eaaf6
There is also a screen in the end of the pressure relief valve, if the screen gets plugged, it can cause weak power steering.  Even if you arn't going to mod the pump, cleaning the screen is a good idea if the pump is already drained.
PS_Pump_050.jpg.09710499dffc371e7e8c4953
And for those curious of the pressure relief valves operation, this is my own personal opinion after staring at it for an hour, could be way off.
Crude sketch
PS_pump_pressure_relief_valve2.png.4e701
When the pressure relief valve relieves pressure from beneath the piston, as the fluid goes through the small tube, there is a pressure loss, once the pressure difference between the top and bottom are 9psi, then the plunger gets pushed down and compresses the spring, opening the big bypass port.
User Feedback
   1 of 1 member found this review helpful 1 / 1 member
Thank you for the excellent write up. It's explained very well.
   3 of 3 members found this review helpful 3 / 3 members
Worked like a charm. Instructions were straight forward. Aces
   2 of 2 members found this review helpful 2 / 2 members
This is a very simple but very effective mod. The results are quite noticeable, especially if your running larger tires like I am (35x12.50).
