Welcome To Mopar1973Man.Com LLC
We are privately owned, with access to a professional Diesel Mechanic, who can provide additional support for Dodge Ram Cummins Diesel vehicles. Many detailed information is FREE and available to read. However, in order to interact directly with our Diesel Mechanic, Michael, by phone, via zoom, or as the web-based option, Subscription Plans are offered that will enable these and other features.  Go to the Subscription Page and Select a desired plan. At any time you wish to cancel the Subscription, click Subscription Page, select the 'Cancel' button, and it will be canceled. For your convenience, all subscriptions are on auto-renewal.
Replacing Later Model ABS Speed Sensors
I would like to make a shout out to the member that sent me the front sensor back in the spring of the year. Long overdue but now I got the time to replace my well wore out and damaged ABS sensors.
So here we go I'm going to do both side. Total time to replace is 30 minutes for both.
Start out by jacking up the front axle and jack standing the axle for safety.
Now remove the tire using the proper socket and impact gun. Mine being aftermarket wheels is a 3/4" socket. After the wheel is removed grab a large flat blade screwdriver and pry both caliper piston back a little. Now using a 5/8" 12 point socket remove the two bolts holding the caliper frame. Now lift off the caliper and frame as a assembly. Now you should be able to remove the rotor.
Note: Early series trucks have the rotors held in place by the wheel studs which requires removal of the unit bearing.
Now grab a proper sized Allen wrench to remove the Allen bolt holding the speed sensor. Now you may lightly bend the shield metal up to gain some room.
Now I'm working with the passenger side so I got to get the BHAF and heat shield out of the way. Now I will have access to the connector up top.
So now just careful remove all the old ABS sensor and lead taking note of where its routed along the brake line and frame. Now route the new sensor in the very same manner. Making sure to snap in the wire in all the clips and push the holders back into the holes on the frame.
Now carefully bend the shield metal back down over the ABS speed sensor. Slide your rotor back up on the wheel studs. If you need to use a pair of open face lug nuts to hold the rotor in place. Now slip the caliper and frame back over the rotor. Grab your blue loc-tite and put a bit on the bolts. Re-install the two bolts holding the caliper frame.
Before mounting your wheel again double check that the wire is out of the way of any moving parts and not going to be damaged. Now remount your wheel and tire and torque your lug nuts.
Now for the lights ABS and BRAKE both lights should go out within a very short amount of travel. Like in my case just getting outside the door frame of the shop the ABS and BRAKE lights went out.
User Feedback
More options...
   1 of 1 member found this review helpful 1 / 1 member
 Thank you for the step by step instructions. Now I know exactly what needs to be done to replace the sensors.
